Pro 3.5.1 - Zoom To unavailable although object is selected
182
06-19-2025 12:51 AM
RTPL_AU
Honored Contributor
Anyone seen this before?
I want to zoom to an object after selecting it in the attribute table but Pro 3.5.1 decided it cannot allow that to happen. Fixed after a restart of Pro.
I unselected-reselected the point a few times with no different outcome. Are there any other ways that are better to "make sure there are features selected"
How can you be sure? I thought I was - the text was highlighted, the point was highlighted after I manually moved there. What else is there to do but believe the UI until it deceives you?
It seems Pro has devolved into the quantum realm where things can be and not be while simultaneously appearing to be yet tell you it isn't to be.
I lodged a case with the locals but it will probably be another "Case closed, non-reproducible" before anyone that can actually do something about it hears of it.
Tags (1)
