Pro 3.3 georeferenced image disappears
3028
16
05-31-2024 01:53 PM
ALV
I have 3 images to georeference but they will not display at all in ArcGIS Pro 3.3.0. I became frustrated and used Desktop to georeference instead and then bring the images back into Pro. The control points are there, the image is where it should be, and the coordinate system is the same as the map. No transparency is applied to the images and pyramids and statistics are built.
Thanks for help in advance!
KeithAddison1
I'm experiencing georeferncing in 3.3.0 as not working at all.  Doesn't matter if I save or save as to a new raster.  I can do whatever (CPs, move, autoref) to get it in the right place, but as soon as I click save (or save as) the raster goes right back to its original location.  Funny thing is it worked a few weeks ago, exact same version 3.30.  Is ArcGIS Pro rot a thing in the same way Windows rot is a thing?  Seems like it is the way stuff just stops working for no apparent reason.
AndrewParker
I am having the same issue.  Just started happening this week.  I am having to export as raster as a work-around.  But resolution quality is lost.
SimaTM2024
Hello everyone, I have the same problem. I do not know why I cannot see my photo after georeferencing and saving it. However, I used another system, and the weird part is that I can see my photo in it, and then I opened my project (not photo). After that, I created an export of my photo and then opened it on my system.
DEAF_PROBERT_68
Honored Contributor
I used  a lot of PDF recently and add them to ArcGIS Pro 3.3.6 and it was fine for me...  Once I save the control points, I then export to a new TIFF to a known project folder .  I add them to my Map View and it overlay correct ... I do not know what you situation was but could you please show the screenshot and it will help us to see the problem......
BTW, When you save the control points, your world file may be saved somewhere in your folder... so if you forgot where they came from then that might be the reason why  it disappears.
ALV
I think the issue was the pdf program my company uses by default - PDFxchange. You can convert pdfs to jpgs with the program which I believe is the root of the problem. When I use an online converter, I do not have the issue when trying to georeference. I have used png and jpg formats since and have not had issues, so if you are still having a problem, it could be the way the images were processed from the original source.
SimaTM2024
Thanks for your response. I do not use PDF; I use some purchased aerial photos from EODMS in TIF format.
DEAF_PROBERT_68
Honored Contributor
Yes I am aware. it can be anything that you can use to georeference such as PDF, TIFF, JPEG, etc
