Pro 3.3.5 Odd date format when creating export folder
541
7
10-10-2025 10:44 AM
ThomasHoman
Hello,
When I am creating a new folder in Pro as part of the  sharing/exporting a pdf to, the date format is really wonky - please see attached. Windows Explorer shows the correct date. so I don't think it is the OS.
I am curious if others have observed this behavior and if their are suggestions for correction. Due to some vendor constraints we are currently unable to move beyond this version.
Thanks for ideas to correct.
Regards,
Tom
RTPL_AU
Honored Contributor
@ThomasHoman @JamesPoeschel
After a quick check - it is known in 3.3  as BUG-000169961
JamesPoeschel
Weird, I dont remember having that issue when I had pro 3.3.5. I have 3.5.0 now and still dont have that, but I dont see any mention of this bug after skimming the 3.4 release issues addressed document.
You could try this:
Verify your Windows region settings (Control Panel → Region → Formats → “Additional settings” → Date) to confirm they’re set to MM/dd/yyyy.
Check ArcGIS Pro’s application language (Options → General → Language).  Make it “English (United States)” assuming you are in the US.
Here's what my region settings looks like in the control pannel. JamesPoeschel_0-1760119325098.png
Not sure anything else you could do but update PRO.
DanPatterson
MVP Esteemed Contributor
List of date formats by country - Wikipedia
ISO 8601 - Wikipedia
It is the international date format used by most countries, so it isn't wonky, just different than you expect.  Check your settings as suggested above
... sort of retired...
DanPatterson
😂  missed the 32.... It thought it was the YYYYMMDD format
off-planet 32 wouldn't ok
RTPL_AU
Honored Contributor
@ThomasHoman
Definitely a known issue in 3.5   BUG-000176711
Can't remember seeing it on 3.3.5 though.
From what I can tell this is only a visual issue and if you check the folder in a file manager it should be correct.
@DanPatterson  I can hand-on-heart say Australia has not moved to 32 month years... yet....  🙂
RTPL_AU
Honored Contributor
Robert_LeClair
Esri Esteemed Contributor
Just an FYI -  BUG-000169961 - is fixed in the upcoming ArcGIS Pro 3.6 release.
ThomasHoman
Thanks all for the replies and confirmation of a bug @Robert_LeClair & @RTPL_AU .
I know I've been working extra and did not want to have to explain to payroll the additional day or few months as appropriate for date formatting lol.
t
