I am currently running into an issue with an XY Event Layer that I cant quite figure out what is going on. Currently I am using an a few XY Event Layers that reference to an Access Database.
Some of these work fine, the pop-up window appears and shows me the record data for each feature. However, some will not provide a pop-up window and will select all the features at once.
I can't work out what is causing the issue as there isnt anything intrinsically different between these layers in terms of structure on the Access end and this seems to happen across other Access databases.
Any idea?
