Popup information not published to ArcGIS Enterprise when using Arcpy?
2484
10
10-30-2020 04:26 AM
JoëlHempenius3
Occasional Contributor II
I've automated sharing my mapservices to ArcGIS Enterprise using arcpy and now I see a difference on the configured popups between the services I share manually from Pro and the services I Share using Arcpy. When I share manually, the popup information is also shared in ArcGIS Enterprise and when I configure the mapservice in a new map in ArcGIS Enterprise the popup configuration  is the same as ArcGIS Pro. When I share the service from Arcpy and add the service to a new map in ArcGIS Enterprise, there is no popup configuration and I need to do the popup configuration again in the webmap.
Using Ago-assistant, I dug a little deeper and found the service I shared manually has a data section containing the popup configuration and the service I shared using Arcpy doesn't have this.
Screenshots to illustrate this:
The services shared manually from ArcGIS Pro has the data section bottom right with the popup info:
The service shared using Arcpy doesn't show the data item:
From the network tab in dev console I see a /data? request, but this gives a 200OK with 0 content length.
I tried a very minimal script from this page (MapImageSharingDraft—ArcGIS Pro | Documentation )  and modified it only to publish my pro project to my server, but this gives the same result.
Does anybody know how I can publish the popupinfo with the service from Arcpy?
-Joël Hempenius.
Languages: JavaScript, Python and Dunglish
StephenRhea_NV5
I'd love to peek at the github repo! I'm going through custom popups in Pro and converting them to Portal popups, so the code in the post has been a great starting point.
