Point Shapefile to CAD File - Circles in Cad instead of Points
6982
9
07-18-2022 01:02 PM
AustinGootee
Hey Question for y'all, anyone know why when i convert a point shapefile to a dwg file via the Export to CAD tool, i get circles instead of points. I've tried changing the symbology to X's and changing the symbology size. Still get the circles.
As reference I'm using ArcGIS Pro 2.9 and Autodesk DWG TrueView 2022
PrasantaBhattarai
Hello Richard,
This is not a bug, but a symbol applied to the point for the CAD layer. You can easily reset the style of the points by using the "DDPTYPE" command in AutoCAD and selecting the style you want to display the point with.
I hope this helps!
Regards,
Prasanta.
DavidForbuss1
Yep I had that happen too.  Something seems to have changed with the export process.
AustinGootee
Any idea on what version of ArcGIS Pro it used to export to just points? I may try rolling back to that version to see if that would fix it.
DavidForbuss1
He said he's using 2.9, but I'm on 3.0 and it's happening with that too.
RichardHowe
I believe this is a bug. I'm seeing exactly the same behaviour on ArcGIS Pro 3. Even when adding a CADType field to attributes and specifying POINT in the field (which should force the geometry) does the GP tool produce large circles instead of points. In direct contrast to what the technical help suggests (i.e. points become points, lines become lines)
Copying in a couple of the dev guys who've helped me before
@CraigWilliams @KoryKramer
Hopefully ESRI can comment on this or suggest a workaround as it's very frustrating that something which used to work, no longer does!!
KoryKramer
Esri Community Moderator
Hi Richard,
I don't work with CAD data, but looked in our Support database and didn't find a bug describing this behavior. It may be and it hasn't been logged yet...
I did read through some cases and technical articles that talk about the Entity field being defined as circle.
For you and others on this thread, did the points you're working with in Pro originate from CAD; i.e. imported into Pro from dwg or another CAD format and you're now exporting again? Check that Entity field if present.
I can ping somebody on our CAD team, but we may need additional details to troubleshoot. If you feel this is a bug, the best thing to do is to contact Technical Support. I'll let you know if I hear back from our dev team on this.
RichardHowe
Kory thanks! No, the data is a native ArcGIS feature class. I did wonder if any fields might accidentally be upsetting it, so I created a copy with every field stripped out and I get the same result. Also running it from a  shapefile instead of a feature class.
In the meantime I am relying on QGIS to export as points
PrasantaBhattarai
Hello Richard,
I hope this helps!
Regards,
Prasanta.
WWalker
@PrasantaBhattaraiDo you know if this can be overridden with reserved CAD fields? (e.g. https://pro.arcgis.com/en/pro-app/latest/help/data/cad/reserved-cad-fields-for-dwg-and-dxf-files.htm)  I was getting circles and am now suddenly getting points with a different seed file.  Thanks!
RichardHowe
@PrasantaBhattarai Thank you for this. I can confirm this is the issue we were experiencing. Thank you for the help. I'm off to drag our CAD operative over hot coals...
