Point layer renders in ArcMap but not in ArcGIS Pro
333
09-03-2025 05:01 AM
Labels (2)
JoseSanchez
Good morning,
We have a point layer that renders in ArcMap or ArcCatalog but does not show in ArcGIS Pro or AGOL when uploaded to AGOL.
The layer is in SDE.
We copied the layer from SDE to a FGDB and the layer then shows on ARCGIS Pro.
Please advise.
AJD
Which version of EGBD do you have? The issue might be a compatibility issue between SDE Version, ArcMap and ArcGIS Pro
George_Thompson
Esri Notable Contributor
Also, what is the RDBMS being used and the version information.....
--- George T.
Robert_LeClair
Esri Esteemed Contributor
Another thing to try is with the eGDB feaure class, rebuild the spatial index - do the points appear in ArcGIS Pro?
