I have ArcGIS Pro on my VDI and the version is 3.3.1 . Each time I exported the PDF and whenever I open it ,the PDF shows white blank for a few seconds before you can see the map shows up later.
Do I need to change the PDF Settings in Pro in the Export or should I change in the Adobe Software and
which software does ESRI uses the Adobe in the Export PDF ?
Is it related the export PDF in ArcGIS Pro ? Is it related to the software from Adobe softare ?
I have two on my VDI that has Adobe Reader and Adobe Acrobat DC Reader .
Can anyone tell me what is the cause ?
