Parks and rec stylx
3835
07-13-2022 11:30 AM
MarkGambordella
Looking For parks and recreation .Stylx or .svg for map we are creating.  Need icons like disc golf, soccer, baseball, swimming etc...
JohnPlunkett
Hi Mark -
If you are using ArcGIS Pro - you might be able to find what you are looking for by signing in to ArcGIS Online
Click Portal and the ArcGIS Online Icon
Search for parks type:style
Then you can look through the style, you might have to try different combinations of Parks, sport, recreation etc... to find what you like
MarkGambordella
thank you for the info,  ill keep checking through AGO
MarkGambordella
how do you download or add the script for the stylx.  there was no file just a code
jcarlson
If SVGs are your thing, you can check out sources like Material Design Icons or Wikimedia Commons.
In the former, you can export any icon as SVG. In the latter, you can specify file type when you search. There are plenty of SVG icon packs out there, just be sure to check their licensing and attribution requirements, as some sources will require attribution.
- Josh Carlson
Kendall County GIS
MarkGambordella
I will check out those two sights , thanks
