Opening a QPT file in Arc GIS Pro
5226
06-19-2022 11:16 PM
ScottJohnston
I have a .qpt template file which was exported from QGIS and I need to use the template in ArcGISPro. Is there anyway to import the file into ArcGISPro? Or does it have be converted into another file?
Thanks in Advance
Scott
Tags (3)
MicZatorsky_AEC
A .QPT file is a QGIS Layout Template. It would not contain data, just the page elements and references to a Map
Its Pro equivalent would be a .pagx layout file, and there is no converter.
RobertBorchert
Honored Contributor
QGIS I believe uses Shapefile which should be usable in ArcGIS pro
However, I believe to use the layout you will need to export it from QGIS as a kml and then import that
You may be much better off just creating the layout from scratch in Pro.  Language barrier and all that
MicZatorsky_AEC
