Number formatting does not carryover from Pro to AGOL
1799
03-21-2019 09:44 AM
by Anonymous User
Not applicable
Not sure if this is a bug or functionality but when I set up my number formatting in fields view in Pro and then publish to AGOL that formatting does not carryover. I end up having to go back through configure attributes and manually change the formatting for everything. Not only is the table wrong but pop-ups are also reset. Like I said, maybe it's a bug.
Another thing that does not carryover are suffixes. Why have it in Pro but not have the ability to publish to AGOL and have those carryover? Seems pointless especially if I have to make arcade expressions to mimic what I have in Pro.
One last thing that I found interesting is when I publish to AGOL it puts thousands separators in everything. Even if I did not designate thousands separators in Pro. I'm running Pro 2.3.1 by the way.
PRO
AGOL
POP-UP
DanPatterson_Retired
That leaves
ArcGIS Ideas
first to see if it has been posted as an issue, or for you to put forward the idea with your use case.
The amendments/additions to tabular data in Pro are 'fluff' and are just additions to make the underlying data look better.  I am not surprised that you see differences in appearance, however, if the values differ (beyond decimal separators and decimal places), I would be concerned
by Anonymous User
Not applicable
I understand is just an aesthetic thing but when I'm preparing to present these maps to the public there is a demand for things to appear a certain way. I guess my problem is however I set it in Pro should carryover to AGOL. I should not have to do this twice. In the example I provided there are 55 total attribute fields that need to be changed. I prefer to do most of my work in Pro before publishing and not have to split my tasks up.
That leaves
ArcGIS Ideas
