North Arrow Rotation issue
8448
8
11-01-2018 01:13 PM
ShannonWhite1
I have a student who created a map where north would be to the right side of the layout.  ArcPro automatically adjusts the compass rose to point the North in the proper direction but then as it has rotated the W & E are 90 degrees off.  I.e. W is on it's side.  How can this be fixed?  #arcpro
KoryKramer
Esri Esteemed Contributor
Here is my interpretation of the issue:
Is that the problem?  You want the W and the E to read correctly?
What about the N and the S?
Or... maybe that isn't the issue.  A screenshot would be great!
DanPatterson_Retired
Shannon, they didn't do something with the modification section did they?
North arrows—Layouts | ArcGIS Desktop
TomBole
Hi Shannon,
If North points to the right side of the page I would expect West to point to the top of the page and East to point to the bottom of the page. I'm not quite sure what you mean by W & E being 90 degrees off.
Could you provide a screenshot of what you are seeing?
Tom
KoryKramer
ShannonWhite1
Yes, Kory that was the issue.  Sorry, I was helping the student in person, posted and  then have not received the screenshot.    You are correct.  It doesn't rotate any of the letters only the compass.  The only solution I could provide in the time frame of the work they were doing was apply the compass rose and then cover with graphics of text.
Shannon
TomBole
Shannon,
North arrows are graphic elements. Only their orientation as a whole adjusts direction. Individual items, such as the letters designating each cardinal direction, cannot adjust independently.  The North Arrow is behaving as expected. Having the cardinal directions also oriented to the top of the page, regardless of map rotation, is an interesting idea.  I would recommend adding this to the https://community.esri.com/community/arcgis-ideas site as a possible future enhancement.
Thanks for the feedback.
Tom
BrittanyBurson
Found this post because I have a request to "north orient" (ha) the directional letters. Would be nice if there was a setting... if anything has changed since 2018 @TomBole let me know! Thank you!
TomBole
Hi Brittany,
Unfortunately, there is no new functionality regarding north arrows. Were you able to add a post to the Ideas site?
Tom
BrittanyBurson
Hi @TomBole thanks for the reply. I just submitted an idea here.
