Newly drawn polygon not appearing
271
04-22-2024 11:34 AM
celtics08
New Contributor II
Version is up to date. I am working on a versioned SDE layer. When I create a new polygon, it doesn't appear until I save and reconcile. I can see attributes for the new polygon and can even run a tool on it. I just can't see it. I don't have a definition query on and the symbology is just a single symbol outline. Any ideas on how to fix this?
George_Thompson
Esri Notable Contributor
There could be an issue with the spatial index on that feature class.
If you stop editing and rebuild the index using the GP tool, then you start to edit and create a new polygon, does it show up?
--- George T.
celtics08
New Contributor II
Index rebuild didn't work, still seeing the same behavior
celtics08
New Contributor II
Thanks for the tip, I'll talk to my DB admin (I can't directly alter this layer).
