Newly added layers visible by default in arcgis pro.
2758
10-06-2016 10:56 AM
SonaSunny
Does anyone know how to change this setting in ArcGIS Pro? In arcmap, we can go to the ArcMap options and turn it off so that when you add large datasets it wont be visible by default. Is this option available in Pro?
Tags (1)
SonaSunny
Found the answer!
On the Edit tab, in the Manage Edits group, in the lower right corner, click the Dialog Box Launcher Launcher.
The Options dialog box opens.
Click on Map and scene
SonaSunny
Found the answer!
-ChrisCraig
this doesn't seem to work on new layers added through "Make New Layer by Selection" Is there a way to make those newly created layers toggled off by default?
-ChrisCraig
I figured out a workaround. After "Select All Visible" I can toggle off the layer and then "Make New Layer From Selection." The new layer is toggled off and contains all the features that were selected. It would be nice if the default option applied to these newly added layers as well. Thanks!
