Network Dataset for Supply Chain Trucks Routing
721
08-19-2025 01:53 PM
VenkataKondepati
Honored Contributor
Hi Team,
I am trying to set up a network dataset for truck routing in the supply chain logistics domain.
Do we have any sample datasets available that I can use to get started?
Since we have quite a few routing constraints to consider, I’m looking for suggestions, best practices, or examples that could help guide us instead of starting completely from scratch.
Any advice or resources would be greatly appreciated.
Thanks in advance!
Regards,
Venkat
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
CodyPatterson
MVP Regular Contributor
Hey @VenkataKondepati
You may want to check out some of these tutorials that the Network Analyst license can utilize here:
https://pro.arcgis.com/en/pro-app/3.4/help/analysis/networks/network-analyst-tutorials.htm
These come with data that you'd be able to experiment with along with ways to test routing constraints as well!
Cody
CodyPatterson
Cody
