Navigating to last row in attribute table doesn't work as expected
2476
04-27-2023 12:57 AM
Bud
Esteemed Contributor
ArcGIS Pro 3.1.1
I have a standalone table in an Oracle 18c database (14,538 rows) that is not an enterprise geodatabase.
In the attribute table, if I click the "Move to End" button, the attribute table only navigates to row 2,000, not to the last row (row 14,538). I would need to click the "Move to End" button again in order to move to the last row in the table.
Video:
Is that a known issue? It doesn't seem to happen for Oracle enterprise geodatabases. Only for non-GDB databases.
I'm aware that I can use the "Load All" button to load all the rows into the attribute table, and then click 'Move to End" to go to the last row. That works, but I still think there's an issue with the "Move to End" button not working correctly on the first try.
Bud
Esri Case #03332811 - Non-GDB Oracle database — Navigating to last row in attribute table doesn't work as expected
BUG-000158623 - ArcGIS Pro - The 'Move to End' button within the Attribute Table does not work as expected while working with tables from regular databases or mobile geodatabase.
Bud
I was able to reproduce the issue when using a mobile geodatabase table.
Video:
At one point, I thought the issue only happened after opening the Diagnostic Monitor. But after subsequent tests, that doesn't appear to be the case. It's happening all the time for me now.
Bud
