Navigate a Map Frame In ArcGIS Pro 2.3.3
1033
06-13-2019 08:01 AM
RolandDuhaime
Within the layout tab, I am not able to zoom into an activated map frame in ArcGIS Pro 2.3.3.  I need to delete the map frame and re-add it for the zoom functionality to be restored.  I am using "Map Series Pages" as well.  Also, the "Layout Properties" under "Map Series" don't give me the option to maintain the current map extent.  If I select the option for "Center and Maintain Scale" the map extent changes slightly and I am not able to use the "Undo" tool to revert back to my previous map extent.
If it helps, Data Driven Pages in ArcMap allowed me to set a specific map extent.
TomBole
Hi Roland,
The ability to navigate an activated map frame that is connected to a map series has been added to ArcGIS Pro version 2.5.
Thanks for the feedback,
Tom
TomBole
Hi Roland,
Tom
