Multiple fields from multiple layers in ArcGIS Pro reports
1526
02-18-2025 07:39 AM
WillBlairCES
I am looking to create an ArcGIS Pro report to show attribute field information for several items across several layers within the same map frame, ideally automatically as I would need to create a few reports a day.
When inserting a new report (non-custom) on the second page it asks to select the Data Source and I can only select one layer so the default template doesn't seem suitable. I can't find a way to do it with custom templates either.
As an example, I'm looking to create something similar to what's below; the layers would be Roads, Rivers and Paths, and the fields are separated by ' | '.
Roads
Street | Number | Floor
Rivers
Name | Distance | Max. Width
Paths
Length | Surface material |
Is there a way to do this via ArcGIS Pro, Portal or Online services?
Thank you.
cpmgisuser
Any progress on this Will?
We are looking to do the same thing
KThoden
We're trying to do the same- to create a report with multiple feature layers and their sources. I only see the option to report for one layer.  Has anyone found/designed a way to do this yet?
SheriNorton
Would also love to do this! I have a map with a dozen emergency response layers that I would like to summarize and group by community in a single report.
