Multidirectional hillshade in ArcGIS Pro 1.1
4778
08-21-2015 06:24 AM
enricobonansea
is it possible to calculate multidirectional hillshade in ArcGIS PRO by raster funcions ?
I usd  this function in Arcmap 10.3:
http://www.arcgis.com/home/item.html?id=403a846855f14539a2c15ff09398e8e5
iI there a way to do this in Arcgis Pro?
VinayViswambharan
The multidimensional hillshade function is a custom raster function developed for ArcMap. Currently ArcGIS Pro does not support custom functions. You can however, implement the function (or any custom function) in python and then apply it to your data using the out of the box python raster function. In this case we have the multidirectional hillshade built in python and shared here - raster-functions/functions at master · Esri/raster-functions · GitHub
Hope this help
Regards,
Vinay
VinayViswambharan
Hope this help
Regards,
Vinay
enricobonansea
grreat!!
thank you very much,
Enrico
YovavZohar1
Occasional Contributor III
Hi Vinay,
I've tried importing the suggested PYD raster function (from the GitHub source) into Pro 1.2, but I get error when I'm using it.
MervynLotter
Did you manage to get Multidirectional hillshading to work in Pro 1.2?  I am having the same problem importing the custom python code.
YovavZohar1
Nope
