Mosaic Datasets and Privileges Dialog Box
2588
05-24-2022 11:01 AM
Labels (2)
RogerDiercks1
I need to set user privileges for a number of mosaic datasets. When I right-click a mosaic in the ArcGIS Pro catalog tab, I do not see any way to access the privileges dialog box. The privileges dialog box appears as an option for other types of data in this geodatabase when right-clicking.
While I was able to successfully set user privileges using the Change Privileges tool and Python, it would be helpful to access the privileges dialog box to view a mosaic dataset's current user privileges. Is it located somewhere else, or has it been removed as an option for mosaic datasets in the catalog tab?
I'm running ArcGIS Pro 2.9.3 and the geodatabase is in SQL Server and is version 10.9.1.
Robert_LeClair
Esri Esteemed Contributor
Roger - I too see this in my ArcGIS Pro 2.9.3 and I'm using a PostgreSQL 12.x database for my mosaic dataset.  I can confirm that I can change privileges in the GP tool (did not use Python).  My guess is that it's simply missing from the right-click context menu.  I'd recommend creating an ArcGIS Idea for this item so it gets visibility to the ArcGIS Pro developers.  I know ArcGIS Pro 3.0 is coming out this summer so "maybe" this functionality is in the new release?
Robert_LeClair
RogerDiercks1
Thanks Robert. I'm glad to hear it's not just me! I agree that creating an ArcGIS Idea is a good idea. I will do that.
JonM32
@RogerDiercks1 Greetings!
This may be a bit delayed, but I remember looking at this thread a while back when I couldn't find this button that was in ArcMap for mosaic datasets. It's been added and is very useful for managing mosaic datasets in an enterprise database!
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
RogerDiercks1
Thanks for reviving this topic! I'm running Pro 3.3.2 now and had completely forgotten to check to see if it was ever added. It's definitely there! While my very simple Notebook in my project for managing imagery has served me well to set privileges, I'm glad this has finally made its way into Pro.
