Migrating mdb folders to gdb to ArcGis Pro without having ArcMap
674
10-16-2024 03:26 PM
LawrenceAndrews1
Has anyone had problems with the Data Interoperability extension in Pro.  My organization has a active license for the extension, which shows up as it should in setup under Licensing but the message that "This command is currently unavailable".
Does anyone have any suggestions?  It is next to impossible t track down the ESRI Administrator for my organization, assuming here there must be one somewhere?
Thank in advance!
Robert_LeClair
Esri Esteemed Contributor
Another workflow to consider is using Python.  There is an older thread here - Solved: how to convert mdb to gdb - Esri Community - that may assist you in the conversion.
