Merging multiple points into one point, depending on a category.
8159
10-30-2022 12:21 PM
DAMAK
I have a layer with many points that I could cluster using the "Find Point Cluster" tool. I would now like to merge the individual clusters, which consist of several points, into one point. I have found the tool "Pairwise Integrated" that basically does exactly what I am looking for, namely merging multiple points into one point. However, in this case I want only points that have the same cluster ID to be merged. Is there a tool that could help me here? That would be great!
The second picture shows some ofthe clusters. All oft them consist of several points, that I would like to have merged.
DanLee
by Esri Regular Contributor
You can do the following:
1. Run Dissolve tool with CLUSTER_ID as Dissolve Field. Make sure this box is checked:
The output should be mpoint features, each contains points belonging to the particular cluster.
2. Run Feature To Point tool on the mpoint features. The output should be points, each represents an mpoint feature, i.e. a cluster.
Does that work for you?
DanLee
AndreaB_
Exactly what I needed today, thank you!!
DAMAK
Thanks a lot! This is exactly what I need. The new layer looks really good.
DanLee
You are welcome! Glad it worked for you. 🙂
