Map Series
985
07-24-2020 04:33 PM
GraceTortorici
Hi all, I am working on a map series. I have about 70 different pages within the series, in which I need different extents for each page. However, I can not seem to get the extents to save once I set them. For example, I set the extent, then change pages within the map series, go back, and my extent is gone. Is there a way to fix this? Also, how do I make each page have its individual extent? TIA!
DavidPike
MVP Notable Contributor
Is there some functionality in Pro to save the current extent into an index layer?
I would generate a fishnet grid index, or series of centre-points attributed with the desired scale / dynamic elements.
Then use that as the index layer.
TomBole
Hi David,
There is no "out-of-the-box" functionality that edits the features of Map Series index layers based on the current extent.
With ArcGIS Pro 2.6 you can create a Map Series based on spatial bookmarks. You can interactively update the extent of a bookmark for a Map Series as much as you would update a bookmark in a Map View. This should simplify some Map Series scenarios.
Tom
