Map Series - Can It Show Only The Feature Being Referenced By The Index vs All That Are In The Map Extent?
14434
13
02-16-2022 09:31 AM
GRmapper
I have a created all the required parts including a layout to support building a map series. Currently when I run Map Series > Spatial I get a series and while each page is the correct extent based on the indexed feature, I see the feature I want but also all the other features in that layer within the extent. I'd like to only see the single feature based on the attribute used in the Layout Properties form (ie one feature ID per series page.
Layout Properties > Map Series
Layer: Index Layer
Name Field: Road_ID
Sort Field: Road_ID
Sort Ascending
Group By: None
In the
GigiB910
Can you clip to a polygon feature? And can this be done using a Bookmark Map Series or only a Spatial Map Series?
AubriOtis
Bookmark map series don't support clipping at the map series level, you would have to clip them in your map. For a spatial map series you can clip to the index feature which will update for each page.
Cheers,
Aubri
GigiB910
Thanks so much for your help!
AubriOtis
Not for a stand-alone table. If the text is based on an attribute table you can use dynamic table text and filter by map series rows, but stand-alone tables don't have that connection.
Cheers,
Aubri
