Map Series - Can It Show Only The Feature Being Referenced By The Index vs All That Are In The Map Extent?
14813
13
02-16-2022 09:31 AM
GRmapper
I have a created all the required parts including a layout to support building a map series. Currently when I run Map Series > Spatial I get a series and while each page is the correct extent based on the indexed feature, I see the feature I want but also all the other features in that layer within the extent. I'd like to only see the single feature based on the attribute used in the Layout Properties form (ie one feature ID per series page.
Layout Properties > Map Series
Layer: Index Layer
Name Field: Road_ID
Sort Field: Road_ID
Sort Ascending
Group By: None
In the
AubriOtis
Ah, that's why. You can't clip a map to a linear feature. You'll need to use a page query in this instance.
Cheers,
Aubri
AubriOtis
There are a couple of ways to do this! You can clip the map series to the index feature or use a page query on the index layer.
Learn more about clipping here (you may have to scroll to the clip heading): https://pro.arcgis.com/en/pro-app/latest/help/layouts/create-a-map-series.htm#ESRI_SECTION1_261CD8CE...
Learn more about page queries here: https://pro.arcgis.com/en/pro-app/latest/help/layouts/page-queries.htm
Cheers,
Aubri
GRmapper
Thank you for the reply. I noticed that when in Map Series I have the Best Fit, Center and Maintain and Use Scale from Fields but I never get access to the Clip to Index Feature checkbox.
Any thoughts on that?
Thanks again!
GR
AubriOtis
Odd, the checkbox should be there below the radio buttons. What version of Pro are you using? Maybe it's an older version before this feature was added?
Cheers,
Aubri
GRmapper
I check box is grayed out and unavailable. Hmm.
AubriOtis
Is your index feature a point layer?
Cheers,
Aubri
GRmapper
No.  They are lines.
AubriOtis
Cheers,
Aubri
GRmapper
I'll give that a go. Thank you again.
GRmapper
Yep That did it. One last thought that will likely lead to a new thread. I have text in my layout as well. At the moment that gets updated as did the map BEFORE applying a page query. So one text field on the layout has all the values of the rows in the it references. Is there a Page Query-like equivalent for the standalone tables that populate text fields?
