Map Properties: Clip to an outline: Layer Clip, not Symbology Clip?
1563
02-14-2023 05:34 AM
AnninaRupe1
Hello! I am wondering if there is a way to use the "Clip Layers" function (Map Properties, Clip Layers, Clip to an outline) that clips the layer but not the symbology? I have a point layer where there are features right inside of the layer I've used to clip with and the point symbology is cut off. I'd like to see the entire symbol of any feature that lies inside of the clip layer.
I know I can export and create a new layer or use a definition query, but I have 20 maps to make and I don't want to have to make new layers for each and the attribute table doesn't have a field that will query out what I need.
KateGIS
I have the exact same problem. Got the solution?
AnninaRupe1
Well, for the project I was doing I ended up selecting all the points inside the clip layer and exporting as a new layer. However, something that's a little easier is to select all features inside the clip layer, right-click on the layer in the Contents pane, click on "Selection," and then "Make Layer from Selected Features." It at least cuts out having to manually export the features.
