Major performance bomb in Building Locators in 3.3?
675
06-24-2024 12:46 PM
DEWright_CA
Very curious why it takes 12 minutes in Pro 3.1 to build a Multi-Role locator using Tom-Tom or Here Address-Points and Street-Lines, but in Pro 3.3 it now takes 2.5 HOURS for the same source-data and same configuration.
ShanaBritt
@DEWright_CA Does the multirole locator you are building contain only the PointAddress and StreetAddress roles? Where is the data stored that you are using to build the locator with, on a network drive, SSD drive on your local machine? Can you provide a screenshot of the parameters used in the Create Locator tool such as the Country or Region and Language.
Shana
