<UND></UND> Tags work inconsistently in Arcade
762
14
02-03-2026 08:52 AM
RandyMcGregor_BMcD
I am trying to underline the first line in a three line label.
ownlab1 = $feature.ParcelID
ownlab1 = '<UND>'+Text(ownlab1)+'</UND>'
The resulting labels sometimes work and sometimes don't.
I get '3232' for example, which is what I want, but also, '<UND>3234</UND>' I can't figure out what is different about lines that honor the underline tag and those which reject it.
Is there any logical reason for this?
Thank you,
Randy McGregor
2 Solutions
KenBuja
MVP Esteemed Contributor
If the text contains a "<" or "&", these special characters break formatting tags. You have to replace them with "&lt;" and "&amp;". This line replaces both (and uses template literals)
`<UND>${Replace(Replace($feature.ParcelID, "&", "&amp;"), "<", "&lt;")}</UND>`
KenBuja
What else is in the label? If anything in the label contains those special characters, then the formatting tags will break. For example, this code
var ownlab1 = $feature.Site;
var other = "This & that";
"<UND>" + Text(ownlab1) + "</UND>\n" + other;
results in this label
This code fixes it
var other = Replace("This & that", "&", "&amp;");
'<UND>'+Text(ownlab1)+'</UND>\n' + other;
KenBuja
RandyMcGregor_BMcD
Thanks Ken,
There are no visible troublemaker characters but there may be something 'wrong' with the  values that are ignoring the <UND></UND> tags.
KenBuja
What else is in your multi-line string? Do the other elements have the special characters?
Robert_LeClair
Esri Esteemed Contributor
@RandyMcGregor_BMcD - I tested this with some of my data and noticed a few formatting issues with your label expression.  Instead of a two line arcade expression, how about this -
"<UND>"+$feature.ParcelID+"</UND>"
It works in my ArcGIS Pro 3.6.x
RandyMcGregor_BMcD
No effect, but I appreciate the suggestion. What's weird is that it works on most labels but not others. My guess is that there are some weird characters are in the mix (but they are not clearly visible.). Maybe a unicode vs straight text deal or something nightmarish like that 😕 Thank you.
Robert_LeClair
That is odd certainly.  Is the ParcelID field a text field or a numeric field? I wonder if you could create a new field say "opposite" of ParcelID and then use the Field Calculator to populate the field?  By "opposite" I mean, if it's a numeric field, then create a new text field to do the field calculation upon, then apply the UND arcade to the new field for testing purposes.
RandyMcGregor_BMcD
Thanks Ken and Robert, I'll give it a try!
RandyMcGregor_BMcD
Oookay, so I decided to enter text and it's still being naughty:
var ownlab1 = "<UND>"+"Hi Mom"+"_</UND>"
KenBuja
This code fixes it
