Lake Contours to Polygons for surface area and volume calculations
224
09-08-2025 09:41 AM
MelissaMitchell
I would like help to create contour polygons from a lake contour line layer. I have tried creating the polygons, but the polygons are created in a ring and I want the plolygons to stretch the length of the lake, like in layers.
For instance if a contour is 0 in depth it should include all of 1-13 feet in depths, If the contour is 1ft in depth then it would include 2-13 feet contour depths. therefore I can calculate the volume of the lake.
Thank you so much for your help!
DanPatterson
MVP Esteemed Contributor
like contour shell in
Contour (Spatial Analyst)—ArcGIS Pro | Documentation
If you have the original DEM as input
... sort of retired...
