Labels do not display in ArcGIS Pro
62466
23
09-22-2020 09:48 AM
Craig_Eissler_Iceman
#Labels are turned "on" and the Field is set; but labels do not display.
I'm working in ArcGIS Pro 2.5.4
What could be the problem?
Thanks!
Tags (1)
JMcCoy
I had this issue and checked all the fields in the table. Under "Shape_Area", the feature had a NEGATIVE value (no idea how...). I ran the repair geometry tool on that one feature and it recalculated the area and began to label the feature properly.
Rick_O_Hara
Changing basemaps can remove some labels. Basemap labels may trump feature labels.
wongL_DNV
I had a similar issue. For some reason, I had "Use Maplex Labeling Engine" checked off - checking it back on solved the problem.
KeithAddison1
Repair geometry fixed it for me.
