LABELS AND EXTRUSION FAIL IN 3D WEB SCENE.
1705
02-15-2024 02:31 PM
ArmandoFreites16
Hello, I don't know why when i publish this voxel a layer of point don't have the correct extrusion and labels.
the good onethe good onethe web scenethe web scene
Andrew--Johnson
In the screenshot I see the analyzer 20027 showing. When you see any analyzer like this you can click on it to open the help which you can find here as well https://pro.arcgis.com/en/pro-app/latest/help/sharing/analyzer-warning-messages/20027-layer-uses-adv...
It looks like this is expected based on the help. I would switch the renderer to a supported one to ensure it is carried over to the web scene.
thanks,
Andrew
ArmandoFreites16
WHERE CAN I SELECT A different "RENDERER"? and which ones are supported?
ArmandoFreites16
Hello Andrew, WHERE CAN I SELECT A different "RENDERER"? and which ones are supported?
Andrew--Johnson
The help link I provided in the original reply lists the supported renderers. This can all be changed on the symbology pane https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/symbolize-feature-layers.htm#...
thanks,
Andrew
