labeling in Arcade
1497
09-04-2023 02:11 AM
IngridAnneessens
I want to label my feature as follows:
when ADRESSTATUS = Gehistoreeerd -> No label
when BUSNUMMER = Null --> Huinummer
When BUSNUMMER is not NULL --> Huisnumer underlined
I keep getting an 'invalid expression'
Can anyone see what's wrong here? Is there a beter way tot do this?
JohannesLindner
tl;dr:
return When(
    Adresstatus == "Gehistoreerd", null,
    IsEmpty(Busnummer), Huisnummer,
    !IsEmpty(Busnummer), `<UND>${Huisnummer}</UND>`,
    "Default value"
A few pointers:
  • return + something is not valid syntax. return something is. More info on return.
  • = is for assignment (this variable now has this value), == is for comparison (does this variable have this value?) More info on operators.
  • You can append multiple string values (what you tried with the <u>), but you have to actually make them strings using quotation marks, and you have to either add them ("<UND>" + Huisnummer + "</UND>") or use template literals, which I did above.
  • Label formatting tags are not the same as HTML tags.
  • For chained if-then blocks, you can use the When function.
Have a great day!
Johannes
ChristopherCounsell
MVP Frequent Contributor
You are missing a ')' at the end of line 5.
IngridAnneessens
I don't see where I have to put it:
if (!IsEmpty(Busnummer)) {return + Huisnummer};
JohannesLindner
tl;dr:
return When(
    "Default value"
A few pointers:
Have a great day!
Johannes
IngridAnneessens
Thank you, Johannes!
