“Label feature in this layer” option in ArcGIS Pro,
1047
10-28-2017 02:47 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is a “Label feature in this layer” option in ArcGIS Pro in the “label class” pane.
Jamal Numan
Asrujit_SenGupta
JamalNUMAN
Thanks Asrujit,
But the “label class” pane appears not to have this option (as it is used to be in ArcMap). Does this mean that turning labels on\off is controlled from the ribbon?
Jamal Numan
MarcoBoeringa
Yes, it is, you need the ribbon as you already discovered. One of those small implementation details you just have to get used to but no big deal.
JamalNUMAN
Thanks Marco. Good to know
Best
Jamal
Jamal Numan
