Json file loads correctly in Portal web app but not in ArcPRO.
357
02-13-2020 04:56 AM
BarryKeight
I have not worked with json files before, but a colleague has supplied a .json file to me. If I use the import option of Draw in portal the data loads correctly. When I use JSON to Feature in Pro it only loads point data with simple attributes. Is there an issue with file format or a missing feture from PRO?
Thank you,
Barry.
