jpgs and world files
633
06-10-2025 07:41 AM
KeithAddison1
When I throw a jpg with a jgw (or jpgw) world file into Pro, they locate correctly when thrown into a map, but the program can never recognize the coordinate system, it always says no coordiate system defined.  I'm trying to understand more fully what goes on when this happens.  I can to use the define projection tool to fix this, it gets irritating though.  Is this because the coordinate system name is not baked anywhere into the file header?  The sids & tifs I get from 3rd parties all seem to have the coordinate system name baked into the header somewhere because Arc can read and tell you which coordinate system it is in, no define projection step needed.  Is this because jpgs can't bake this information into their headers?  What makes jpgs different than the tifs and sids in this regard?
RobertCao
Hi @KeithAddison1 ,
Have you tried enabling the 'Use world file to define the coordinates of the raster' option to see if that resolves the issue?
Robert
KeithAddison1
Yep, I'll try disabling it just for curiosity.
Luke_Pinner
MVP Regular Contributor
Yes. JPEGs do not have any spatial capability inherently, they're a simple image format. SIDs are a specially designed spatial raster format. TIFFs can have custom tags in the file and the GeoTIFF spec uses this to spatially enable TIFF files.  World files don't contain a coordinate system, just the parameters for an affine transformation matrix. ArcGIS can determine JPEG coordinate system from *.prj or *.aux.xml files, but sounds like you don't have these sidecar files.
RichardDaniels
Honored Contributor
example of a .prj file contents for WGS 1984.
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433],
AUTHORITY["EPSG",4326]]
