Join Feature service with Csv using Add Join tool using Python
1065
09-14-2023 04:24 AM
BhupendarBhandari
Hi,I am trying to Join A feature service with an excel sheet's data using Add Join tool and both of them have a field in common below is the snippet:
now = int(dt.datetime.now().timestamp())
file_name='data_table'+str(now)
file_path=os.path.join(os.getcwd(),"MyProject1.gdb",file_name)
arcpy.conversion.ExcelToTable(xlsx_file_path, file_path)
arcpy.MakeFeatureLayer_management("https://services7.arcgis.com/yxpZft6sXAxt864n/arcgis/rest/services/countries/FeatureServer/0", out_layer='fclyr')
arcpy.MakeTableView_management(file_path, 'table_view')
arcpy.management.AddJoin('fclyr', 'ISO_A3',file_path, 'iso_code')
Here, I am able to create the join but not able to map one to many relationship between the tables, also the join created as a result has random field namesimage.pngimage.pngimage.png
can anyone help?
DanPatterson
There are lots of warnings about "unexpected results" in the help topic (eg both files being indexed)
Add Join (Data Management)—ArcGIS Pro | Documentation
You might be advised to create a gdb table first prior to doing the join rather than relying on non-local data in a non-native format.
Have a read through the help topic to see if you can modify your workflow to overcome some of your observations
... sort of retired...
