Join and Field Calculator issues with Pro 3.2.0
1009
11-30-2023 10:02 AM
Eugene_Adkins
I updated from Pro 3.1.1 to 3.2.0 yesterday, but I came across some major functionality issues with a basic process and I'm wondering if anyone has faced the same.
I'm dealing with a published feature service (with an Enterprise GDB via Portal 10.9.1) that includes a feature class and a related table.
When I join the table to the feature service based on the facility ID the relationship is based upon, the Validate Join process gives no error, and the numbers of resulting input table and join table match perfectly.
After applying the join, the joined data appears in the attribute table as normal, but if I try to update field information in a table column based on field information from a feature service column the field calculator appears to run "normally" but the data does not get copied.
This issue did not occur until I updated to 3.2.0 ... has anyone noticed anything similar? As of now I'm going to have uninstall 3.2.0 and go back to 3.1.1 because 3.2.0 is making it impossible for me to complete my workflows.
Thanks!
ZachBodenner
MVP Regular Contributor
I've experienced something similar that I suspect might be related though superficially it's a very different process from yours:
I was very excited for the single-workspace editing session option in Pro, so I upgraded to 3.2 and enabled it right away. So I had a feature class with related table in my egdb. I joined the two (GlobalID - GUID) and tried to run a field calculation and got basically an nothing-burger of an error message. After some fiddling, I was able to get the field calculation when joined to work, but I had to go back into Pro's editing options and uncheck "Enable and disable editing from the editing tab."
Again, might not be related but I have encountered issues with joining and editing.
Eugene_Adkins
Thanks for that idea, Zach.
Just checked the options and "Enable and disable editing from the Edit tab" is currently unchecked on my end.
I talked with tech-support, but I was not able to follow-through completely with the Enterprise GDB team because I simply don't have the time to troubleshoot because I cannot complete normal workflows with this version of Pro.
chill_gis_dude
I manage an ArcGIS Enterprise deployment and we have noticed similar issues after upgrading to Pro 3.0 and higher and have completely gone back to 2.9.
We have models that run weekly to do select by locations and then calculate the geometry (acreage) of those selected polygons and have noticed that it is calculating erroneous acreages inconsistently. An obvious 20 or 40 acre polygon being calculated as 6 acres etc.
We have also noticed similar issues with field calculator where we are just calculating field3 to be a simple concatenation of field1 and field2 and have noticed that it pulls in data from other fields not even referenced in the expression.
We've pretty much lost all faith in the field calculator and calculate geometry tools, two of the most important tools in Pro. Its like buying a calculator and the "+" not working correctly every time. Trying to get them logged as bugs but the issues are very hard to reproduce.
Our layers are stored in an enterprise geodatabase driven by SQL Server 2016.
