Issue with Map Layout: Long Lines of HTML for Esri Licencing at Bottom
1292
11-30-2021 02:13 PM
ChristopherCharles-Noriega
The screenshot says it all.  How do I fix this issue in the layout window in ArcGIS Pro?
AubriOtis
Is this displaying on the map or did you add the service layer credits as dynamic text?
Cheers,
Aubri
It is not displayed on the map. I went to create a layout and it automatically displays at the bottom of the layout with no service layer credits as dynamic text applied by me.
AubriOtis
Interesting, I've never seen that happen before. Can you tell me what version of Pro you are using and what basemap? There might be a bug somewhere.  In the meantime, you can add dynamic text for the service layer credits and style it to fix your layout. This 1 min tutorial shows you how: https://www.youtube.com/watch?v=Zm96Qiy8gy0
Cheers,
Aubri
Those default credits sitting in the bottom corner of your layout's maps could look better. They used to drive me crazy until I learned from Heather Smith how to manage them. Here's how. May you go forth with well styled credits! Check out some other social channels where I share how-to's and ...
