Is there a way to import/export ribbon toolbars in ArcGIS Pro?
2423
12-18-2017 11:41 AM
EvanMosher
We have to set up custom toolbars and we were looking for a way to export or save the toolbars to load in other installations. Right now we have to do this manually and it is quite a time consuming process.
Evan
DanPatterson_Retired
totally untried, but on the list to check...
Template projects.... various ways to share and various things that can be shared, but not an exhaustive list is given, just an exclusionary one.
EvanMosher
Interesting, will check this out. Thanks Dan.
DrewFlater
There is some info in the comments of this blog: ArcGIS Pro: Ribbons, Toolbars, and UI Hacks | ArcGIS Blog
ToddTurner
Did you ever find a good solution for this?  When giving someone else a project file, there really ought to be a way to give them the custom Ribbon Tabs that were created to go with it.
EvanMosher
We went with creating a custom configuration using the ArcGIS Pro SDK for .Net, through this custom configuration you can specify the toolbar.
