Is there a way to get the Extent of a Table Frame to match the element?
1051
07-25-2019 02:15 PM
SamanthaGriffore
Hi, I'm playing around with the Table Frames in my ArcGIS Pro project and having some difficulties snapping the table to my guides. This is the same for other elements as well that are created using the Insert functions. Since I have to create a box where the element is going to be, the selection extent is never the same as the extent of the actual element. Unfortunately, for snapping, it uses the selection extent and not the element extent forcing me to resize as carefully as possible to get my elements to line-up nicely. (image below of the extents, )
I'm hoping that I'm just inserting my elements incorrectly and there is a simple solution to getting the extents to match.
TomBole
Hi Samantha,
Which version of Pro are you using?  Pre-2.4 there is a bug where snapping was not honoring any gap applied to element frame decorations (ex: the border of an element).  This has been resolved at 2.4.
Hope this helps,
Tom
TomBole
Hi Samantha,
Hope this helps,
Tom
SamanthaGriffore
Unfortunately, still on 2.3.2.
