Is there a streetview add-in for ArcGIS Pro
51212
55
02-16-2017 10:47 PM
MervynLotter
MVP Regular Contributor
Hi there
Is anybody aware of a streetview add-in for ArcGIS Pro?
Thank you.
Jimmy_Simpson
Not sure what to tell you here. The code isn't executing chrome, it is made to call a URL to windows which then windows will open in your default browser. Would check your default browser settings in windows and you can also test by just having a website shortcut to something generic. Opening a website shortcut should be the same general action that Pro is trying to trigger, so if the shortcut doesn't work then you have Windows issues.
You can also just use the built in browser/dockpane in the latest release without having to use an external browser.
Bud
Esteemed Contributor
If anyone finds they can't get the Google Street View URLS to work for them in the above add-ins (in their version of Pro, such as a pre 2.9 version), I wonder if a last-resort option could be:
Create an add-in that copies the lat/long to the clipboard. Then the user would paste the coordinates into the Google Maps search bar. That might still be better than looking up the address, etc. manually in Google Maps/Street View.
ArthurHenriqueAntunesCruz
is there any adaptable addin or github folder for the latest version? 3.2.1 or 3.3.0?
Jimmy_Simpson
The 3.1 version still works through Pro 3.3.1. Not going to bother updating the addin unless there is a Pro update that breaks it.
KurtTowler
Thanks!
Kurt
TimSemmelhaack
hi has anyone tried the addin in 3.4? I got an error "application stopped working"
