Is there a streetview add-in for ArcGIS Pro
51232
55
02-16-2017 10:47 PM
MervynLotter
MVP Regular Contributor
Hi there
Is anybody aware of a streetview add-in for ArcGIS Pro?
Thank you.
Jimmy_Simpson
Yes, clicking on the street open the street view in your default browser.
Would be curious your code for opening it inside of Pro.
BrianBulla
Honored Contributor
Hi.  It's super easy really.  Just add a dockpane with a WebBrowser control in it.  Then instead of opening a browser just assign the url to the dockpane WebBrowser.
//Open the dockpane if it isn't already open
                    DockPane pane = FrameworkApplication.DockPaneManager.Find("ArcPro_DSM_Settings_Dockpane");
                    pane.Activate();
                    //Access the web control through the View
                    DockpaneView myView = DockpaneView.MyDockpaneView;
                    myView.currentUri = new Uri(@"https://www.google.com/maps/@?api=1&map_action=pano&viewpoint=" + lat + "," + lng);
                    myView.streetViewControl.Navigate(@"https://www.google.com/maps/@?api=1&map_action=pano&viewpoint=" + lat + "," + lng);
SheriNorton
Newbe to configurations (non-programmer)! Would love to implement the dockpane versus browser view of StreetView, but not sure how this is done? Where would that code block be used?
BrianBulla
Honored Contributor
You just need to add a new ArcGIS Pro Dockpane to your Visual Studio project, add whatever controls you want to it, and then get it to work with the rest of your code.  I would say to find a Dockpane sample in the ArcGIS Pro samples and then just customize to work for your situation.
BrianBulla
Honored Contributor
OK, I'll work on cleaning up the code I created an post a version onto GitHub.  Similar, but using DockPanes.
Jimmy_Simpson
@BrianBulla The 3.0 version is still reporting as targeting 2.8 and won't load in my v3.1 - I sent you a direct message when you get the chance with a couple other questions.
BrianBulla
Honored Contributor
OK, so here is my version of a StreetView tool.  This was compiled for Pro 2.9, so it will not work in 3.x.  I only have access to 3.0 and one of the libraries I use is not compatible, so I will have to wait till I have access to 3.1 before I can post an update.
AddIn and code available here:
https://github.com/bbulla24/ArcProStreetviewTool
Jimmy_Simpson
Based on @BrianBulla's code, I have re-wrote the original tool to use a dockpane and the built in WebView2 browser with Pro 3.x. This release is only for 3.1 though. I also worked on the "Link to Active Map" and now the map and street view should stay in sync with each other. Also included a direction arrow on the map when you pan around in street view to show what direction you are looking in. Can't promise this is completely stable.
https://github.com/jsimpson746/arcgis-pro-addins/releases
KurtTowler
This is terrific. Thank you!
MicheleBrugnolli
HI , add-in don't work on my PC , i think there is a problem with privacy setting of Google, there is another way to open Chrome ?
For example open app Chrome With URL " \\...\Chrome.exe & url"
