Is the “find and replace” tool available in the latest version of ArcGIS Pro,
8074
36
11-17-2017 12:24 PM
JamalNUMAN
Legendary Contributor
Despite the fact that there is a workaround for this, however, this tool is heavily needed as it is considered the main SEARCH tool. What is the point if searching the data is not straightforward?
FAQ: Is the Find and Replace tool available in ArcGIS Pro?
https://support.esri.com/en/technical-article/000014591
Jamal Numan
DanPatterson_Retired
Click on a text field's name first.
It appears to be a protection so you don't try and replace on a numeric field
click in a field on the thing you want to find and replace.
Then....
JamalNUMAN
A field is selected, nevertheless, the tool is not there!
Jamal Numan
click on "com" directly under the field name.
If that doesn't work, then there is something different or off with your installation or the source of your data
JamalNUMAN
A sample data is attached.
I think the Pro has an instable behavior, some time it activates the “find and replace” command while in other cases it fails (as shown in the screenshots above)
Jamal Numan
You seem to have trouble clicking on the first record under the field name
JamalNUMAN
I’m clicking the first record, nevertheless, the command is not there!
Why should I have all this panic just to get simple command worked? It’s used to work fine in ArcMap with no such implications
I would appreciate if esri experts\developers can comment on this
Jamal Numan
esri experts will way in when you file an issue with tech support I suspect,  they don't routinely follow all threads looking for issues to pursue.
This will get you
Works for me!
That leave you to keep trying
JamalNUMAN
Thanks Dan for the prompt help. I’ll try to communicate with esri support to report this very frustrating issue
Jamal Numan
