I'm new to GIS and am using the ArcGIS Pro. My question is: Is the default in the legend for ArcGis Pro (graduating colors) a range instead of less than symbol? Mine is in a number range instead of the < than. How can I change it if I want to do so?
Hello @bee ,
If you are using a more recent version of Pro (such as ArcGIS Pro 2.8), the Graduated Color (and Classify) should both be using a range now. It was an enhancement request from many users, so the range label were re-established.
If you are using Pro 2.8 and this is not the case, you should contact Support, since there is something not quite right going on.
Hi @bee ,
Symbology is based on the data that is viewed or added to your map, are you using a Raster based layer?
can you share an image?
