Is possible to publish a Geoprocessing service using only python on ArcGIS pro
2271
03-10-2020 03:25 AM
Cristian_Galindo
In the process to publish a python tool, I came to the part of automate the deployment process. i start using python for it.
reading the documentation i found CreateGPSDDraft—ArcPy Functions | Documentation
as well as Upload Service Definition—Help | Documentation
The first function use a parameter connection_file_path ( A string that represents the path and file name to the ArcGIS Server connection file (.ags).)
The second function in the example 2 shows how to use the ags file for the connecttion.
How can I create the ags file using python in ArcGIS Pro?
Is it possible to make all this process publishing to an ArcGIS server having a user with proper rights and its password (no ags file)?
MaxSquires
RobertBorchert
Honored Contributor
You may be able to use the Upload Service Definition Tool and bring that into a  model that you can export to a python script.
Cristian_Galindo
The use of the proposed tool does not solve the main question: How can I create the ags file using python in ArcGIS Pro?
neither answer the second one: Is it possible to make all this process publishing to an ArcGIS server having a user with proper rights and its password (no ags file)?
JoshuaBixby
MVP Esteemed Contributor
I suggest using the ArcGIS API for Python to publish/upload SD files:  arcgis.gis.server module — arcgis 1.8.0 documentation.  In terms of the GIS Server connection files for CreateGPSDDraft—ArcPy Functions | Documentation and similar tools, the connection_file_path parameter is optional, i.e., you can create a draft SD without having to connect to a server.
MaxSquires
