Is it possible to trace the lines in a vector PDF?
309
a week ago
HollyTorpey_LSA
Asking for a friend (literally... a colleague asked me this yesterday and I had no idea): does Pro have a tool or workflow that allows users to easily trace lines in a vector PDF? She said it is easily accomplished in Trimble software.
I'm not talking about feature extraction... just tracing similar to how we can trace line and polygon features using the trace tool.
Thanks!
- Holly
Neal_t_k
MVP Regular Contributor
If it is a vector PDF, you can add it directly to your map and use the same trace tools you mentioned, you would just need a target feature class to hold the traces.  If it is not a vector pdf, you can convert to a tiff, georefence the image and then trace the shapes.
Tracing polygons to create feature classes from a ... - Esri Community
HollyTorpey_LSA
@Neal_t_k So if it's a vector PDF, the trace tool can snap to the lines in the PDF as if it were a feature class?
- Holly
Neal_t_k
It appears when you bring the pdf in it flattens everything to a raster...no snapping.
Robert_LeClair
Esri Esteemed Contributor
I know you said not feature extraction but are two new tools coming in ArcGIS Pro 3.7 that will do this workflow.  See Raster to polyline extraction - Esri Community for details.
HollyTorpey_LSA
Yes, I went to a session about those at the Dev Summit. They look cool but in this case I just want to be able to snap to the lines in the vector PDF. Thanks!
- Holly
