Is it a bug or a feature that the calibrate route tool merges route parts?
516
07-01-2021 11:51 AM
JaniceBaird
Occasional Contributor II
Hi All,
I am new to using the route tools in ArcGIS Pro. I am using ArcGIS Pro 2.8.1 on a Windows 10 machine. I have a route that I am using to test the tools. The route was created from 5 polylines using the Make Route Tool. I was very happy to see that the route was created as a single route made up of 5 parts. I used some tool to create points at the start and end of each segment (I think it was called "Feature Vertices to Points"). I made an edit to the route and extended one end a few hundred feet. Next, I ran the Calibrate Route tool and selected points along the route that corresponded with the ends of the individual parts to use as calibration points. When the tool finished, I had a nice route with the measures at the calibration points held to their original measures.
The issue I have is that the route is no longer made up of 5 parts. The tool merged 4 of the parts into 1 so the route now only has 2 parts.
Is there anyway to prevent the Calibrate Route tool from merging the parts? Or, maybe there is a way to divide the route into parts that match the original parts.
Thanks for any help or suggestions,
Janice.
Tags (3)
DanPatterson
what does Split Line At Vertices (Data Management)—ArcGIS Pro | Documentation
result in?
... sort of retired...
