invert y-axis of graph
1153
05-20-2021 09:46 AM
DirkPeterson2
I'm trying to create a line graph of 2 different readings for alignment sheets where the y-axis is inverted (industry standard).  Is there a way to do this?  While it was simple in regular ArcGIS, I can't limit the graph to just what is shown in the map frame like you can in Pro so won't work.
Robert_LeClair
Esri Esteemed Contributor
Dirk - would you be able to provide a screen grab of what you've created in ArcMap and looking to create in ArcGIS Pro?  Thx!
DirkPeterson2
The top one is from desktop, and the bottom one is from Pro
