In Arcgis "pro" - is there a way to convert labels to annotation for a "single" layer? I only see a tool to convert labels for an entire map.
6243
17
12-22-2017 09:37 AM
AliForrester
I only see a tool to convert labels for an entire map.  I just want to run this for an individual layer.
WendyHarrison
Hi Ali,
To label for a single layer it's just a case of turning off the labels for the other layers in the map and then running the tool.  You can easily do this on the labeling view of the contents pane.  The image below has labeling on for the Roads layer.  When you run convert labels to annotation at this point, only the roads labels will be converted.
Robert_LeClair
Esri Notable Contributor
I too only see the Convert Labels to Annotation GP tool for the Input Map vs. a single layer.  I guess one workaround is to add a single layer to a temporary map, set your label properties and run the GP tool.
DanPatterson_Retired
annotations are handled differently in Pro, so that is probably the reason
http://pro.arcgis.com/en/pro-app/help/data/annotation/managing-annotation-feature-classes.htm
WendyHarrison
Hi Ali,
by Anonymous User
Not applicable
Really frustrating. Agree that "pro" should have common ArcMap functionality.
KoryKramer
Esri Community Moderator
You'll get this in ArcGIS Pro 2.4 slated for release in June/July https://community.esri.com/ideas/15058-convert-labels-to-annotation-functionality-similar-to-arcmap
danashney
Rediculous
Aghyan
Too much effort and times for just converting two streets labels to annotation in PRO. I had to turn off more than 20 layers. It crashed two times and I lost all updated on the map! In the end, I wasn't able to move the annotations to the place I wanted !!
SterlingLoetz5
I agree, this is absolutely ridiculous. I waste so much time converting labels to annotation in pro. ArcMap is almost instantaneous compared to Pro. Just populating the parameters in the Convert Labels to Annotation geoprocessing tool takes ten minutes because Pro just sits there spinning it's wheels. I was very excited to use Pro and now I regret moving large projects to Pro.
WendyHarrison
Hi Sterling,
are you seeing this lag with the tool after the geoprocessing cache has been built?  if you run a different gp tool first and then this one do you still see the lag?
thanks
wendy
