Importing shapefile to a GDB in Arcgis Pro
1719
6
05-06-2024 09:30 AM
ENRIQUEVELA
Currently using ArcGIS Pro 3.2.1.
I imported a shapefile to a Feature dataset inserted in a File Geodatabase, I don´t get any warning message, but some data from the file is missed. I checked extent, name lenght, data propieties but I can´t find the possible error.
Thanks in advance for your help.
DanPatterson
MVP Esteemed Contributor
coordinate system : WGS 1984 UTM Zone 18S
data :  polylines  polyline ZM
        :  32 records   many fields are empty, perhaps because of a temporary join
removed some extraneous files so that I could run a repair geometry.  see the attached
If there is geometry or attributes missing, then you will have to return to how it was created in the first place.
... sort of retired...
DanPatterson
what type of data are missing?  geometry? attributes?
a validation of the geometry is done when bringing features into a gdb, so bad geometry would get removed.
ENRIQUEVELA
Geometry and attributes.
Thanks
ENRIQUEVELA
Thanks for the information. I followed the instructions, I runned Check and Repair Geometry, but the error persists. I attached the file with the problem, to have a look of it.
DanPatterson
ENRIQUEVELA
Thank you very much.
